I have a 1957 10hp Johnson Seahorse. I bought it and It had compression on both cylinders in the 60's. But it needed all new gaskets and impeller. So I took it apart and replaced the head gasket,exhaust gasket and the powerhead gasket, and the impeller also I cleaned out the carburator. Put it all back together and checked the compression before I put gas in it to start it. And I am getting no compression at all on my gauge???. I tried to start it anyway and it back fired once so I just left it alone and came inside. Thanks for any advice as to why this happend or what to check. Thanks. It had compression before I replaced the above. I used the same gauge. So I am off to tinker some more. The gauge is only 2 days old. I used it on my 5.5 hp 1954 Johnson and it worked. Plugged in to 10hp and no compression.
