"1984 CHAMPION w/150 MERC, ser
"1984 CHAMPION w/150 MERC, serial #6501746, I've owned this baby for 4 years & she's been real dependable. Everytime I've taken her out she's run real strong. If there's a problem, it's usually a quick fix, like a switch, a bulb or just an adjustment of some kind. Anyway, while I was bringing the motor down using the trim/tilt switch located on the side panel next to the control shift box, my buddy mistakely was doing the same thing with the trim/tilt switch located at the bow of the boat. NOT GOOD, doing this caused us to lose all power, everything shut down real quick. Could'nt do much out on the water, so after getting her home I tested & got 'continuity'at all of my switches, to include the trailer switch on the control shift box. The Voltage at the (2) batteries were strong, both the 20A & 90A fuses next to the trim pump, & the 20A inline fuse by the head were still good. I sure would appreciate any suggestions you might have on what I should do next. THANKS,PETE}}}}"
