Westernlife
Hey everyone, so I made an oopsie this weekend and hate myself for it.. I was out Friday evening and was out exploring when I ended up in a channel, which I usually always try to avoid channels especially with this motor since I try to baby it... went through no problem but on the way back I smacked what I assume was a rock since I couldn't see anything under the water at about 1/2 throttle, It caused the motor to pop the trim lock and fly up... Instant regret, I checked the motor best I could and didn't see anything so drove back to shore at about 1/2 throttle and meant to check it the next day but forgot and got back on the water... Half way through the day cruising along and bang engine instantly shuts off and I couldn't get it out of gear had to fight with it and then couldn't even turn the flywheel. So I got towed home and noticed the Crack on the lower unit so I assume it puked out all the gear case oil and then self destructed, I pulled the lower unit off and found lots of metal shavings, the motor seems fine though... So I have a 85hp that's also around a 77 year, can I put that lower unit on for now and see if I can fix this one later on? Kind of tight with money right now and would like to be able to finish this year off.
