Collecting the winter antifreeze
rcahill31
"The engine is a 1988 OMC 5.7
"The engine is a 1988 OMC 5.7 litre, with the engine cold can I turn the engine over with coil wire removed and collect the anti-freeze, I looked at the diagram and assume with the outdrive raised that it will come out at the exhaust bellow, kind of a dumb question but I do not want to spill the anti-freeze on the ground or in the water."
"Ayuh,...
Just remove the b
"Ayuh,...
Just remove the block,+ manifold drains...
Then it'll run out into the bilge,..
Then drain the bilge into a Bucket...
Turning the motor over will Not drain anything..."
"All I did yesterday was pull
"All I did yesterday was pull the drain plugs, let it drain, and sucked it up with the shop vac. Re-bottled it, and dropped it at work in our scrap antifreeze bin."
