wynjim55
I've almost got my 2 cylinder 55hp Mariner (made by Yamaha late 70s early 80s) water worthy. Today it took a bit to get started - starter pinion gear doesn't like meshing with the flywheel - but ran beautifully at idle and with some gentle throttle manipulation. Once it warmed up I turned it off and back on a few times. In the end I turned it off and let it sit for a while but decided to let it run until the fuel in the line was used, however I couldn't get it to start again. The battery (borrowed from the car, quite old too for a battery) seemed to be dropping with each new attempt but I was wondering if it might be something else that I've overlooked, any thoughts??
thanks in advance
thanks in advance
