Cold start 6 hp johnson
gapedal
"Hard to start when motor cold
"Hard to start when motor cold. Checked carb, new plugs, good compression, fuel pump good. Read article here about the labrynth seal leaking between cylinders. Where is this seal? Never heard of it."
dont know about your question
dont know about your question about the seal but you can go to shopevinrude.com and get exploded parts diagrams and complete parts descriptions.
maybe you can find it there if nobody else answers your q.
"that is prob not your problem
"that is prob not your problem,...it is part of the crankcase...i see this alot on 2 cyl 50's 55's.
if your upper seal is lking,u will get oil on points etc."
thanks to this forum i was abl
thanks to this forum i was able to look up the year of the motor. It is a 1987 model johnson
"You have a 1987 mdl johno whi
"You have a 1987 mdl johno which doesnt have points, the labrynth seal between the crankcase halves consists of a couple of grooves that fill with fuel\oil and provide a seal between the cylinders this wont be your problem. has your motor got a butterfly choke or a primer like we have here in Australia?"
