"This is raw water cooled
"This is raw water cooled (no heat exhcanger )and it will not come up to operating temp. The engine runs fine, but infrared readings at the thermostat housing read 105-107F at 3000rpm. I have tested the stat (160)and it checks out to spec, but the temp never gets up to where it would come into play.I have a good mechanic who thought there might be a problem with the stat housing,but that checks out OK. We replaced the plates between the risers and manifolds with ones that restricted water flow, but there was no change. I bought the boat a year ago, and it has always run cold. I thought that it had a bad stat, but obviously this was not the case. Any ideas on this would be greatly appreciated. By the way, if I run it up to 3600+- for a couple of minutes and bring it back to idle, the temp will briefly rise to 120-130, but then returns to 105-107 as soon as I throttle up.Help."
