Cold start lever moving forward?? Has this worked okay in the past?
I assume you're speaking of a procedure to cold start the engine?
Describe your control system.... Regular OMC side mounted control box, top mounted control on center console, what?
http://www.marineengine.com/parts/j...XESS&manufacturer=Evinrude§ion=Remote+Control Is this your control they are fairly simple to take apart and put back together it is more than likely a worn nylon bushing. Take it apart and give it a thorough inspection and replace anything thats worn. The bushings and washers are cheap but the hard parts can get spendy. It would be a good time to replace the cables while you have it apart they should move smooth and easy. Use a good marine lithium grease (liberally) when you put it back together. Clean all the electrical terminals and connectors good also.
