I have 1987 454 350 hp engines with electronic ignition. My question is if the module in the distributor is bad will my coil still fire? I am getting 12 volts at the positive side of the coil and with the other lead grounded on the engine block with my tester. When I try the starter with one lead on the positive side of the coil and the other lead on the negative side of the coil I get no voltage. Also, when I pull the coil wire off the distributor an hold it against the block while turning the motor over i get no fire. I swithched coils to a new one so I am pretty sure I works. If anyone has any ideas, they will be greatly appreciated.
