Cobra sterndrive question
jmorton
"I have an 89 Bayliner with a
"I have an 89 Bayliner with a 5.0 liter engine and a Cobra outdrive, #985687. I tore up the gears on the upper unit last summer. I found a complete drive for $100 with a bad lower unit, #984540 out of a boat with a 2.3 liter engine. Will this outdrive work on my boat or should I sell it as a core?"
"nope.. the 2.3 wont work, the
"nope.. the 2.3 wont work, the gears in the upper are different.
keep looking.. you'll find one."
"Is it a different ratio then?
"Is it a different ratio then? I looked at reman units on Sterndrive.info and they list the same drive for the 2.3 through the 5.7. If the teeth on the gears count the same, will it work or is there other differences?
Thank you!"
"Different Ratio, Same Lower,
"Different Ratio, Same Lower, different Upper. call Sterndrive !!! I have seen people post on here that Highly recommend them, even people from over the pond !!"
"Where are you finding the upp
"Where are you finding the upper gears for $350? Are they hard to replace? I'm a Ford tech but don't do transmissions or gears. If possible, I'd like to just replace the gears but the only one's I've found are $650-ish."
