Cobra outdrives
Are the outer shells the same?
Are the outer shells the same? If i were to rebuild one new gears etc. could i use the 4.3 out drive as a starting point?
"The drive will bolt up but no
"The drive will bolt up but not only are the upper gears a different ratio, the LU is the larger V6/V8 version.
This unit requires a larger prop which you will have difficulty turning with your L4 engine."
