[FONT="]do these pumps sometimes go erratic when they are starting so die? Or is it a case of just crapping out. I have a no start issue on port motor, I can hear the pump run when ignition is on but I’m not getting fuel to the carb. I checked fuel flow all the way back to the fuel manifold. Even swapped the fuel line to the stbd side which runs. Does this sound like fuel pump? It cranked fired and immediately died. Never to fire again. It’s been acting up for a while. i replaced the spin on , i blew out the fuel line from the spin on to the tank valve manifold , even swapped the line to the stbd engine valve which is a known runner. can this be the pump / oil pressure sender? ive ordered new of each and hopefully will solve the prob. also , on the holley carbs , if you press the accel pumps near each of the bowls, should i see something spraying into the barrels?[/FONT]
