Clonking sound whne turning
bully515
"Hi all, when turning tightly
"Hi all, when turning tightly to the right and accelerating slightly the leg/rear end of the boat makes a clonk noise.. does anyone have any ideas what this might be ?"
"Post a make and model...Mercr
"Post a make and model...Mercruiser, Old Stringer..Volvo..? On the old Stringers like I have, it may be the ball gears. This is just a guess. Lots of folks on here know WAY more than me."
"Sorry, Boat is a Sunbird Cors
"Sorry, Boat is a Sunbird Corsica 19'6. Engine OMC 5.0L V8 inboard with a cobra stern drive.. Could it be the prop shaft ?"
"Is it a repetitive "clonk
"Is it a repetitive "clonk", or a one timer? If repetitive and only when turning hard I'm think'in U-joints."
"I would agree with Chuck as t
"I would agree with Chuck as the u-joints the most likely, when was the last time the drive was off and they were greased?"
We've actually just taken
We've actually just taken the stern drive off.. but if you all reckon the U-joints we'll take a look at the weekend.. is it just a case of re-greasing or can there be some serious damage.. apologies for the lack of knowledge but this marine stuff is new to us.
thanks
If the noise is not there in t
If the noise is not there in the straight ahead position but develops when you turn the steering it will be uni joint prob and they will need replacing not greased...just trying to save you pulling it down again.
"you also may want to check th
"you also may want to check the gimbal bearing, bad u-joints put more stress on the bearing. you may want to check the condition of your upper bellows to."
