chriscraftcat
"On my Crusader 220 I recently
"On my Crusader 220 I recently replaced motor starter and solenoid. Everything worked OK for a few times then she could not start anymore. I am hearing clicking sound from the starter area. At first I thought it was a battery, then I switched cables to the second battery and the same No Start clicking occurs. I would imagine it is not a new solenoid on the new starter, but it could be a slave solenoid under the Circuit Breaker switch. Is this correct or not? The only one thing I did not do is jumper the starter posts to see if engine will crank, which would pin point the problem with slave solenoid. Am I on the right track?
Thanks"
Thanks"
