Classic fifty overheat
kwhite771
alarm sounds at wot. has about
alarm sounds at wot. has about 10psi water pressure good stream from pee hole but water is really hot. good way to flush the system?
"Kevin check the basics first
"Kevin check the basics first do a compression test just to make sure the compressions are all ok, remove the lower unit and check the water pump impeller"
