Classic 50 not peeing
I replaced the impeller about this time last year,started the motor yesterday,was not peeing, rush to the house took old Impeller out, had no damage, no water pressure showing on the water gague, what could ths be??
Is the engine temperature rising?If not,probably a plugged tell tale.Poke the tell tale with a bit of weed eater or a blast of air.
Water pressure gauge may be faulty.Can you hold your hand on the block for thirty or so seconds,comfortably? If so poke the tell tale.If not,you have a blockage in the block.Salt water or fresh water? Shallow/muddy?Might have picked up dirt and blocking the water passages.Pull the pressure gauge,put some air through the block.Not much salt water in Arkansas,oops:eek:
