Circulation problem
cehmass
Advanced Contributor
here may be a simple question about cooling ,
just did rebuild on 87 evinrude 90 .just got it fired up the other day , problem is one head seems to be getting hotter"
"Did you check the water defle
"Did you check the water deflectors when you had the engine torn down? See the following.
(Water Deflectors)
(J. Reeves)
Water deflectors are actually lengths of 3/8" outside diameter rubber hose, installed between the top cylinder and any cylinder beneath it, and also between the bottom cylinder and the block. The purpose of the deflectors is to have the water follow a definite path around the cylinder walls. Unfortunately the deflectors between the cylinders will at times swell sideways due to either a previous bad overheating problem, or simply due to age and salt corrosion. This causes a water flow restriction which usually allows the water to cool sufficently at low rpms but not at the higher rpms.
This hose material can be purchased reasonably at any automotive parts type store if you care to make your own, or you can purchase individual deflectors at any Evinrude/Johnson dealership at a somewhat higher cost.
Removing and installing them can be a hassle at times, but not always. I use a sharply pointed scribe with about 1/4" of the tip bent at a right angle whereas I can reach in, jab the tip sideways into the rubber, then yank it out. It's necessary to clean the seating surfaces where the ruber contacts the block with a small rat tail file to eliminate salt deposits etc. When installing the new rubber deflector, coat the deflector and the metal surfaces with WD40 which will act as lubrication to allow it to go in as easily as possible.
Make sure that you insert something into that deflector area before cutting and installing the deflectors if you make your own so that you will be certain that they are the right length and also that they will be seated properly. Usually a very small amount will be left extending about the block sealing area..... simply cut the excess off with a single edge razor blade.
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
"how did u adjust the ring gap
"how did u adjust the ring gap?...if the rings are too tight,it would sure make it run hotter.Are u getting water discharge,from prop area?....verify head temp w/a temp gun if poss...usually one side will run warmer than the other.Another thing i would do,is disconnect the hoses,leaving the heads,at the thermo housing.Then,start it and see if it runs cooler,if so,your prob,is a restriced discharge,in some way,..if it does not run cooler,then u have a water delivery prob,or too tight of clearances,between piston skirt,rings,or,water jacket restriction in block,or head,or some other mech prob."
