"Hoping someone has some thoug
"Hoping someone has some thoughts on this. The carb doesn't seem to be getting a consistent flow of gas. I took the line off to the carb and cranked her over- it squirts a good amount of gas a couple times and then the flow fizzles out. I blew compressed air into the tanks and confirmed that gas is getting to the fuel/water separator filter. I changed the filter and primed it by filling it with gas. I reconnected the filter and she turned right over and ran for an hour, no problem. Two days later, the same problem- she'll start and run for a few and then cut out- starved for gas (or so it seems to me). Any thoughts on the cause? I've gone out a few times with no problems. I come back into the marina and try to start her after a couple days and she gives out after a couple minutes. Thanks for any help"
