FstaRockr Burns
Was looking at a broken shift cable, traced it all the way down to the transmission.. Removed cables and they are fine.. Seems trans is locked up in neutral (i presume) since the motor has been running but not moving :0
Here is a pic - seems the mounts for the motor are on the trans/bell housing - Do I need to remove the mounting bolts to remove the transmission?
See the pink fluid, is this atf mixed with water? What could be the cause? And is it possible to try free the lever first with penetrating oil?
