Guys,
I am trying to get a 1974 century resorter back on the water. It has a Chrysler M440. It has been sitting for 10 years. I started it today with the inboard flush kit on it. It mounts underneath the boat. Once the boat started, I turned the water on. It ran for about 20 seconds and no water came out so I turned it off. I checked the thermostat and there was none installed. I will correct that. My question is does the water pump need to be primed? I pulled the pump out and the impellers look good but it was dry. I also plan on flushing all the lines before retrying. If priming is required, how is that done?
Thanks for the help.
