I ran into a bit of a problem with my 1966 Lonestar/Volvo Penta 270 .... probably should have changed the pump impeller but I didn't .... When I launched the cooling system didn't prime and the engine somewhat overheated by the time I moved from the ramp to my slip, maybe 10 minutes and the gauge was reading about 240. When I was trying to get the pump to pick up, the exhaust was blowing backward thru the cooling system. I did get the cooling system going but now, shortly after start-up I get this rattling noise like loose tappets or something rattling in the drive train and the noise stays. Everything looks normal - no smoke from the exhaust, no blow-by from the crankcase vent so I don't think I buggered it badly but something isn't right.
I will try new spark plugs but what else could have been effected by overheating? I can't think of anything but a bad plug that would cause the noise and higher than normal vibration.
Any other ideas?
Thanks!
Any other ideas?
Thanks!
