I bought this motor cheap knowing I had to replace a water pump impeller, as former owner said it wasn't pumping water. Bought an impeller(not cheap-paid more for it than I did for the motor), tore motor down, water pump impeller looked good but changed it anyway as long as it was apart. Put is all back together. Started it up and I don't get any appreciable water coming out of the unit. Tore it down again, all the way, blew out pressure line to engine, blew out engine passages both ways and blew out the outlet pipe. Now in looking at it, I'm wondering where the water does come out. The outlet stops about midway down the tower, so I guessing there is no tell-tale like other engines. Can I route this to the outside to "make" a tell-tale or what. I'm hestitant in putting this back together until I figure out how it's supposed to work. Does the water dribble out of the small holes lower on the midtower?Thanks.
