Marksa1458
All - looking for some wisdom on the best way to move forward. I have been working on a 1975 Century Arabian with a Chrysler m440 reverse rotation and a paragon pv41 transmission and v drive.
The boat partially sank and was never winterized properly. Got the engine running today (you should be able to click on the below pic)
To see the video
here is what I got
-the engine runs and starts up immediately
-there is white smoke coming out the left side riser (this maybe due to a bad seal on the riser cap plate)
-both oil coolers have freeze damage
-the engine backfired twice while I ran it
- the exhaust elbows most likely need to be replaced
- oil is clean and shows no signs of water after running
-compression tests showed the following:
left side front to back
100 / 120 / 100 / 120
right side front to back
120 / 110 / 105 / 105
- the case for the vdrive is severely cracked on the outer water jacket, can't see any cracks on the inner cavity but there was water in there so I am assuming there is.
- transmission appears ok, but not 100 % sure
- I have a spare reverse rotation cam
looking for your thoughts to move forward. Should I have the engine rebuilt, look for a used engine vdrive setup, do something else?
i did speak to one shop and they said they would send it out to be rebuilt and all in I was looking at about $3,500 - not including transmission v drive work. Or I could do new for 9-16k. I'm not afraid to spend money, but 9k is way out of my budget. Thanks for your thoughts.
To see the video
here is what I got
