"I have an oil leak from the i
"I have an oil leak from the intake manifold that sprays oil on to the fuel pump. I removed the manifold and re-installed with new gaskets to fix the problem. Now I have more problems.
1. Exhaust leak, Did not install both restrictors, it looked like the manifold had a built in restrictor on one side.
2. Still leaks oil from the front onto the fuel pump. I did not use the cork gaskets I use a high temp gasket product that comes in a can that you spray. It comes out in a quarter inch bead. I put a heavy amount on front and rear.
I did not notice any leaks in the slip, but under load and at temp leaks appeared.
Question:
What should I have done differently?
What is the best type of gasket sealer for this job?
What is the bolt torque for the intake manifold ?
Any help would be appreciated."
Question:
