hawkeyes16
I think I have finally got this sorted anyone who like me has searched the internet for details of the duel impellor set up will know there is little info out there and much conflicting info.
I have a mid seventy's 318 marine motor and it is fitted with an alloy eddlebrok 2176 intake. first issue is the front water passage on the 2176 intake is straight across connecting the head ports, I overcame this by fitting an alloy baffle plate beside the thermostat aperture effectively making 2 separate chambers , also to help overcome corrosion I epoxy painted the interior faces of the water passages. the raw water route that appears to be working now for me as follows;
thru hull intake piped to rear pump connector - rear pump exit port splits to 2 smaller hoses that connect to exhaust manifolds at the top front end then water flows through the exhaust jacket (distribution pipes correctly fitted) and out of the manifolds at the rear into the top of the transmission oil cooler- the water then runs to front pump intake port and into the cast water crossover device and into the starboard block- back through the head and into the 1st camber of the intake not the one with the stat in, - then out of the intake by way of a u hose into the other crossover passage -then in to the port block- head and out to the thermostat chamber of the intake manifold water passage, the water is pretty much up to temp straight away then stat opens and water runs to exhaust elbows and overboard, there is a smaller out put bypass to the thermostat top hat housing that sends a constant stream of water to the exhaust manifolds to cool them, this flows through the manifolds from the front lower inlet to the rear outlet that fills the tranny cooler and joins the loop etc.
I ran the boat which is 1956 Chris craft Capri 21' last Sunday, it ran good, temp gauge was constant 180deg. f with little fluctuation gauge may not be accurate, manifolds were warm to touch about 120, block was even temp good flow out of exhaust .
this system is renown for misinterpretation ,incorrect fitting and variation, later it appears that Chrysler issued a service bulletin that did away with the duel impellor system, at present I have decided to stick with it, does anybody have any further advice or comments to add to this topic, It seems to me for example that the starboard block is cooled before the port block with pre warmed water which when it enters the port block must be at a higher temp sounds a bit mad to me, also I have seen the raw water routed direct to the tranny cooler without going through the exhausts, and some guys don't fit the distribution tubes at all ?
I would like to complete the information trail on this to try and save others the long slog of trying to search out the facts, this was particularly difficult for me being in England and there not being any boats to go have a look at.
thanks for all your advice
David
David
