I have just purchased a 1964 Tollycraft with a 318 Chrysler engine. The motor starts easily and runs smoothly.
The compression is good but there is "blow by" at higher RPM.
The previous owner cruised at about 1600 RPM max (often short distances) and claims that this is both ideal and adequate for such an old motor. The mechanic says the blow by is probably due to the rings being gummed up by being run at such low speeds and often
for very short distances. He says the engine can run at 4400 RPM and suggests that cruising and running longer at 2400 - 2600 RPM
with a gas and oil anti gunk treatment added might free the rings and reduce the blow back.
The previous owner is convinced that that would damage the motor.
Anyone have any idea or thoughts about what RPM this motor should be run at ?
Thanks.
Brian
Thanks.
Brian
