Chrysler 1974 6HP cuts out and dies after running a while
chaspcox
"My Chrysler 62HF starts fairl
"My Chrysler 62HF starts fairly easy when cold, runs good at first, but as it warms up it starts to buck. I'm fairly sure it is preignition not just a miss. When the motor heats on up it will finally die and wont hit a lick until it cools back down. Motor is not overheating, as I can actually put my hand on the head for a few seconds without getting burnt. Water pump is working good. Any help would be greatly appreciated.
Charlie"
"Charlie, sometimes ignition c
"Charlie, sometimes ignition components will work fine when cold/cool, but can short when they heat up.
If you can find yourself a manual and an ohm meter, you can grab a blowdryer (for hair), heat your components up and test. If a "heat short" is your problem, that will let you quickly determine what it is...."
