JerryJerry05,
Cheers for that, to be honest im an expat "Eastender" living in Calabria Italy.....No where near Auss...lols. As for the "Profile???" part of your response........You lost me there mate?
To be honest im surprised that the motor is that old, its in cracking nick and runs like a good un (i did strip it down and rebuild it mind, just for peace of mind if nothing else) the only thing is that the mechanism for the engagement of the fly wheel, the part that the cord and engagement wheel sits in, is cracked in three places, this presents me with a problem as its made from a plastic resin that sits on a steel spindle (when you pull the cord, this then, via centrifugal force, engages the flywheel) and being as im a diesel fitter by trade and marine engines are not exactly my forte, im not sure what its called? Therefore its like looking for a needle in a haystack, if i knew its proper name, it would make life much easier, so basically if you or any one else for that matter that reads this post knows the correct name and would kindly tell me i would be able to try and locate one, fit it and finally, after three months of work.....Go fishing!!
Cheers
Mark
