Just a word of warning. If your Chris Craft has a Hercules Engine. DO NOT SET IT ON THE FLOOR ON THE FLAT CAST IRON OIL PANUN-ATTACHED . IT WILL STAY THERE UNTIL IT IS BUMPED AND IT WILL FALL OVER ON THE CARBURETORS !!!!!! THE CARBS WILL BREAK OFF AT THE ATTACHMENT BOLTS!!!! I have read other posts that people are hunting for other carbs to get parts to repair there set of two carbs that are on a KFL. Make a stand or keep your engine lifting eye hooked to a chain. The water manifold and carb or carbs make these engines heavy on that side and will stay upright long enough to get you in trouble and fall over if not harnessed. 1st Hand Experience!!!!
