dale_genther
"I have a 1962 CC Sea Skiff wi
"I have a 1962 CC Sea Skiff with a 283 engine in it. The rew water pump is coupled in series with the generator on the stbd. side of the engine. I need to replace the impellers (I think there are two in the pump). The pump is in a very inaccessable spot. From looking at it I can't tell for certain how to disassemble it to replace the impellers. The old CC manual I have says to remove "four caps screws", but gives no additional information. The only four matching screws I can see are what looks to be the ones to the coupling that attaches the pump to the alternator. There does appear to be 5 or 6 slotted machine screws that look more likey to be the correct ones to replce the imnpeller. Can anyone lead me thru this impeller replacement process?"
