"I just replaced my carburetor
"I just replaced my carburetor. It's a 1976 120 Mercruiser with the two barrel carb. (2GC/2GV) The old one had a mechanical automatic choke, the new one has an electric automatic choke. The guy I bought it from said all I had to do was connect the terminal on the choke to the + side of the coil. I looked in the manual and it appeared that he was right, so I did it that way. I also ran a ground wire to the carb and plugged the heat riser from the exhaust manifold because the new carb doesn't use it.
So my questions:
1) When I turned on the ignition, the choke did not close. It's a moderately warm day, so should it have?
(The engine did start.)
2) How does the choke know when to open/close if it just has one positive lead from the ignition switch and no heat riser?
Thanks,
--FatBear"
So my questions:
Thanks,
--FatBear"
