"ANY COMMENTS ON CHECKING RPM
"ANY COMMENTS ON CHECKING RPM WITH HANDHELD TACH ?
THE TWO IV'E FOUND ARE : CLIPS ON TO PLUG WIRE
AND OTHER USES STICK ON TAPE TO SAY FLYWHEEL AND METER CHECKS IT DIGITALY WITH LAZER ,DOES THIS SOUND RIGHT ? WHAT IS FULL PROCEDURE? THANKS !!!!
ALSO THE FUEL CONNECTOR (COMING FROM EXTERNAL HOSE GOES TO ENGINE CONNECTOR) CLICKS IN PLACE BUT ALLWAYS SEEMS LOOSE (NOT A TIGHT FIT ) NO FUEL APPEARS LEAKING BUT COULD AIR GET IN SYSTEM ?
JUST KINDA HANGS DOWN NOT STRAIGHT OUT AND TIGHT... THANKS FOR ANY INFO !!!!!!!!!"
