check valve hose routing
uncle d
I have a 1983 115hp.crossflow. Could someone plz give me the correct routing for the check valves recirculation hoses from intake to bypass covers. Thx Don
Just run the hoses so that they do not connect to the same cylinder they lead from ie...............
(Example, depending on hose length)
Run #1 to #3
Run #3 to #5
Run #5 to #1
Run #2 to #4
Run #4 to #6
Run #6 to #2
I hope he can follow that as he's got a V-4.
Oh, okay, well then............. :p
(Example, )
Run #1 to #3
Run #3 to #1
Run #2 to #4
Run #4 to #2
There was one setup whereas the intake port covers had dual nipples... been wondering if it was this 1983 model. I think I have a graphic on that somewhere and will look for it.
The only thing I can remember is they changed that flow set up when they came out with the VRO. They sent more oil to the center main bearing.
