Hi all, 2004 Captains Choice 8.1 engine -- I'm getting a check engine light on my the port engine before starting when i turn the key. The boat is still layed up for winter so I haven't tried to turn it over yet; the last thing I did was winterize / change oil with fresh water from a hose and all seemed fine; I can't imagine this would be related, but also just replaced a bad tach on the same engine and don't recall getting the light/alarm when checking that tach with ignition power in the fall. I noticed the issue yesterday when checking to see if the new tach was getting signal.
Since the engine isn't running when getting the error, is there anything I can easily check for issues, or will I need a code reader (I don't own one) / mechanic to take a look?
Thanks for any advice
