Benzsavant
I have a 1990 yamaha 25hp 2 stroke, New Plugs Newly rebuilt Carbs and new fuel pump diaphragm, New fuel filter, new primer bulb and lines
Starts right up on first pull runs smooth. Motor will run all day at 1/4 throttle with no problems. I can run smooth at 1/2 or full throttle smooth just about enough time to plane for a minute or two then will choke down to an idle speed like its starving for fuel or running on a single cylinder for about a minute before throttle comes back. At that point I can immediately throttle up again to a plane before it happens again. Happens every time the same way. Primer bulb stays nice and stiff the hole time, ive tried venting fuel tank with no change. Any input would be greatly appreciated.
