charging system 1988 johnson 110
either a regulator or a rectifier depending on which you have....you have two yellow wires coming from the stator...trace them and see what they feed...if its a regulator its probably a black box mounted right behind the flywheel on the block...if its a rectifier only they will feed a rectifier about the size of a quarter or a little bigger mounted on the starboard side of the block....
