spiritofstsimons
I have a pair of 9.8 epuls on a sailing catamaran. Separate starting batteries in each hull are isolated from each other. Also have a house battery for electronics in the console, also isolated. BUT, for a Coast Guard certification, I am required to have a way to parallel the house to the starting system(s) and to parallel the starting systems, if needed. Seems easy enough, just 1- run a parallel wire from each terminal on the starting batteries, across the hull, connecting them and put an on off switch in the hot wire. and 2- run a pair of wires from the house battery in the console and connect them with a three way connector to the two new crossing wires, and put an on off switch in the new hot wire that comes off the house battery. That should allow me to use the three batts in any combo. QUESTION: will this muck up the alternators in any way? THANKS
