Hey, if Jeff can do a report, so can I!
Problem: Starboard Chrysler 360 has a couple of low pressure cylinders. #5 is at 95 lbs. The boat is a 1980 Silverton 34C. Time to take the heads off and see what's happening.
Location: An ice cold shed in Connecticut. Maybe that's not cold to others but I'm old and it's very cold to me.
What's happened: Took the exhaust risers and manifolds off. The risers are heavier than when I changed them a couple of years ago. The manifolds came off but not without a lot of effort. The exhaust manifold on the off cylinder side didn't look good. Intake manifold next. Really difficult to get to the mounting bolts. Some new offset box wrenches did it, finally. Then off with the rocker arm assemblies and after that, the heads. The rocker arms and push rods looked like new.
Next: Two new exhaust manifolds. Keep the risers since they are only three years old. Two rebuilt heads. All new grade 8 bolts and gaskets. Most of you good mechanics could do this a in a day. It will take me at least two weekends and, I won't be able to start that engine until spring. Cost? Creeping up on $1500.
It's good we really like the boat.
Bill
Bill
