discobayken
1983 aq1125a / 270
I'm getting ready to change the Timing Belt & tensioner. Should I also consider the following while I am in there?
1. changing out the circulating water pump
2. taking apart and cleaning the heat exchanger and/or replacing seals/gaskets
3. rebuilding the alternator ?
the above systems ARE currently working but its is a 27 year old boat. I have owned it 8 years and none of the above has been done on my watch. I dont have unlimited funds... but, do I plan on taking her outside the golden gate for salmon one of these days. It would really be bad to break down out there. I want her to be reliable.
I do plan on installing a water separator in the near future.
Carb just rebuilt, electronic ignition installed with new coil, plugs, wires, rotor and cap. new starter, new battery, new raw water impeller.
Outdrive to be serviced and new bellows installed.
El P, Ricardo? anyone care to chime in here? What should I do above and beyond what I have listed to make her as reliable as possible without going overboard ? (pun intended).
Thanks!
Ken
Thanks!
Ken
