I'm changing all 8 of my engine mounts and got 3 of 4 done today on one side. If you recall my post from last week, my fairly new cutless bearing was worn (and the rubber was loose, maybe a manufacturing defect). I noticed when the boat was hauled that the shaft was a lot closer to one side of the shaft log. I'm going to get it dead center and do whatever I need to do to the cutless bearing to keep it that way. Then I should be able to do an easy alignment with all new mounts.
What I noticed in removing the mounts was the pinch bolts that clamp down on the trunnion weren't super tight. I was the last one to tighten them and intentionally did not over torque them. Since I have to remove the bracket and mount (not enough room to slide the mount off the trunnion and clear the stringer), I found out something interesting on the bench.
You have to torque the bolts really tight so the trunnion doesn't slip on the mount. Much tighter than I would normally tighten a bolt of this size. Do you guys find the same? Now I know why the shaft was so much closer, the engine must have "walked" to the left over the course of the season. I think what I 'll do is use some touch up paint to mark the final position(s) so I can check them during the season.
What do you guys think?
Bob
Bob
