Changed ignition coil still no spark
Theb
1995 crownline 250 cr with a MerCruiser engine 350 5.7 Bravo. Changed the ignition coil and cleaned every connect that i could find.. I get 12 volts on both sides on ignition coil .. distributor cap is clean.. Battery at 12 volts.. Kill switch is fine.. It was sitting for about 3 years.. I got it started at first with starting fluid and a bottle of fuel for about 30 seconds than quit had to change fuel pump.. So it did start.. But now there is no spark ..Not sure y I did not mess with anything Electric .. But I think it quit after I had it running.. And help woulb be well appreciated.. Thank you
