I have a 1991 15 hp Evinrude model E15EEIA. I replaced a defective CD unit last year. Today I took the flywheel off for an unrelated issue and found that the metal piece extending out of the CD unit had been busted off by the flywheel. I disassembled the original CD unit and discovered the metal is actually a core to a coil. I believe this coil must activate the trigger circuit. Believe it or not the engine still runs fine however I am going to replace the CD unit again. I thought the problem was probally bad bearings causing the flywheel to wobble but I can not move the shaft at all. Has anyone had this problem before or have a better solution other than filing down the metal piece so it is flush?
