Jimmy10681
Picked up the 2001 140 the other day been trying to get it started, the solenoid was bad so i took one off my mercury wired it in and cranked it in doing so the ground wire at the bottom of the cd mounting plate gets hot and is melting the insulation, i took it loose and tried to start it and it threw a spark from around the choke coil but wouldn't crank, put the ground back on and it turned over but still smoking the ground wire, any ideas? It smoking the gnd wire when i was jumping out the original solenoid too so it's not a solenoid wiring issue.
