procraftforce
Hello everyone, Im brand new to this site and owner of a 1986 procraft 1750v with a Force 150 (1991 i think) my question is this....i put the boat in the water for the first time yesterday and discovered a few gremllins......#1 an alarm went off in my throttle control after about 15 minutes of running time at idle ( it also did this when I hooked it up to a hose at home) is it an overheat alarm? its pissin water #2 , when cruising half throttle and boat plained off its cavitating big time noticed the top of prop is only 8" below bottom of boat what should the proper depth below boat be? #3 when you grab the bottom of the motor (prop,lower unit) I can move the motor out and in(back and forth) about 2 inches, does this mean the mounts are bad in the motor and lower unit thanks in advance
