Fisherman_7
I just recently changed out my older motor to a newer one. Everything is fine except, the boat wants to pull to the right at higher traveling speed. Am I correct by adjusting the cavitation fin which is located under the plate on the lower unit will correct the pull? Also do you adjust it to the same direction of the pull? I have an Evinrude 150HP. Any suggestions would be appreciated. Thanks
