"I have a 1999 7.4L with Bravo
"I have a 1999 7.4L with Bravo 3 outdrive. When I plane the boat0about 3500 RPM, my engine alarm goes off. Water temperature is fine, oil pressure is fine, gear oil reservoir is full. If I stay slow, less than 2500 RPM, the alarm never goes off. I've pulled each sensor wire and that is not the cause. any suggestions??
Will the knock sensor set off an alarm?"
