The bottom carby on my 50 hp will not tune properly. Took it to local dealer for cleaning and ran worse on return pilot / idle mixture screws wound out 4 turns on top 2 carbs and bottom screw closed fully off and carbs weren't balanced when I checked myself., Cleaned carbs (many times) and balanced. Top 2 carbs now run well at about 2 turns open on idle mixture screws but bottom carb idle mixture still wound closed. What am I missing? could the float be too high and its flooding on that cylinder? This motor was secondhand with only 150 hours on when I got it but that doesn't mean it wasn't played with by "experts" prior.
