john rauch
motor is a 96 E6RED 6HP. Had oil coming out of air box on front of carb. There seemed to be a lot of oil sprayed around inside the motor cover. Removed and inspected Leaf Plate per fuel system trouble check chart. One set of reeds or leaf valves are sitting tightly against the surface of the leaf plate, other side is slightly open to a point where you can see light at ends of that set of reeds. The opening is about a 1/16 of an inch. My question is, are the reeds supposed to be tightly seated against the reed plate? Motor was great at high throttle; but was running rough at low idle speeds.
Just looked at parts diagram, I see the Leaf plate has a small check valve built into it. could this be my source of the oil in air box.
