Carburetor Core Plugs
martino
Under what circumstances would
Under what circumstances would you replace the core plugs? I have never done this on a carb rebuild. Any down-side?
"Martino,
The plugs are gen
"Martino,
The plugs are generally there to allow access to orifices or jets that might need to be cleaned.
There is no trick to it; just punch or drill a small hole in the plug and insert a stiff awl into the hole and pry the plug out.
To install a new plug just place it in the recess and tap the center with a wide punch until it flattens out. A little gasket sealer around the perimeter of the plug will seal any small air leaks.
Tony"
"Martino,
It is a good idea
"Martino,
It is a good idea to do this whenever you clean out the carbs.
Tony"
Why? Is there crud behind them
Why? Is there crud behind them that you can't otherwise clean? Thanks again for the assistance!
