jcoughenour
"1990 Yamaha 115 HP,only used
"1990 Yamaha 115 HP,only used in fresh water & very low hrs. Don't get to use as often as I would like. Between usage sits up in inside building storage, the carbs are always gumed up when get it out to use. Sometimes 4-6 months between use. Will crank good, but will not perform in water. Bogs when you try to gain speed. I have used two of the major brands of gasoline additive. I have to have carbs rebuilt (cleaned) each time out, to the tume of $200 to $300. QUESTION Is there a better way to prevent and can I clean myself?? }}Whats envolved? Thanks, JHC"
